Nano VNA V2 2_2 Touch screen rotated 180 degrees on startup after 20201013 firmware update?
n4mf 2021/04/29 07:46
As the subject line states. I purchased a Nano VNA v2 10KHz-3GHz from Ebay. I have no functional issues with the unit. The unit came with ver 2_2 firmware dated March 2020. I updated the firmware to the 20201013 version which works well but I have a problem now with the touch screen being 180 degrees rotated on power up. I can use the buttons to recal the touch screen and all is well again but Is there something I can set to fix this power up screen problem, TIA
Mitch
N4MF
Dave (G1OGY) 2021/04/29 16:29
I don't see it as a problem, Mitch.
I have used the 'flip screen' menu option deliberately to have the
connectors at the top.
More ergonomic IMHO.
On Thu, 29 Apr 2021, 16:17 , <n4mf@twc.com> wrote:
Dave (G1OGY) 2021/04/29 16:32
Sri
'flip display' under 'Display'
On Thu, 29 Apr 2021, 16:29 Dave (G1OGY), <g1ogy@g1ogy.com> wrote:
aleks07111971 2021/04/29 09:00
Config-save
n4mf 2021/04/29 14:55
The screen itself isn't flipped. It's the touch panel over the display. I have to recal it every power up, the regular screen is right side up..
Mitch
N4MF
Siegfried Jackstien 2021/04/30 02:53
calibrate touch screen and SAFE the setting
dg9bc sigi
Am 29.04.2021 um 21:55 schrieb n4mf@twc.com:
n4mf 2021/04/30 07:25
Thanks Sigi that seemed to work. Time will tell.
Mitch
N4MF
