Hello, I cannot use VNA-QT on a Win 10 PC, the driver is involved, I reinstalled it I changed the USB socket,
but nothing wants to work! I did a test on another Wnd 10 pc and it works? help please
Thank you Roger ON4BK.
Common problem in Windows. Check the Windows Device Manager. If there is
a COM port associated with the VNA, then it should work. If - likely -
no COM port found, check for unknown devices and try to update the
driver (with Windows default settings). Did the trick for me.
Op 10-11-2020 om 11:31 schreef Roger:
> works? help please
IDcircuits - RFID & Electronics
Het Halster 40
6581 JL Malden
The Netherlands
+31 633702492
www.idcircuits.com
r.gerritsen@idcircuits.com
Hey Roger
updated windows version 2004 ? this messes up the driver.. it finds a Serial to Uart.. but no com port.
even no Unknown Device...
did try with original Cypress Uart driver.. but no advance..
Didn't find any solution for the moment..
I reverted to version 1909
It worked again..
Strange
JP
hello Jempi,
how to get back to this version? I can't find anything valid! Thank you for kl'aide 73's Roger
Hello JP.
Thanks for the information, Windows 10 (1909) version works fine for NANOVNA-QT.
73's and again Thank you. Roger
