Measuring power (how to interpret what I see)
ploegmma 2021/01/16 12:23
Hi. I would like to do power measurements with the NanoVNA but I'm not sure how to interpret the readings I see.
This is what I did:
Calibrate (full calibration with open, short, load and thru) for 15kHz - 15MHz
only trace CH1 LOGMAG active
Signal generator 7 MHz sine, connected to port2 (vary the amplitude setting on the signal generator from  10mV - 1V)
This is what I see:
Peak at 7 MHz, dBm varies but not with expected values.
This is what I expected:
I measured the signal of the generator with an oscilloscope and calculated the dBm values for the signal using the peak-to-peak values measured by the scope. I assume 50 ohms and used log(10)((Vpp squared * 1000) / 400) * 10. I double checked my results with on-line calculators as well.
The values I read from the NanoVNA are about 33 dBm off (lower).
Does that mean that the value it calibrated against (from port1) is 33 dBm? Did I make a mistake in my setup or calculation? Or is it not possible what I wanted to do here?
Dragan Milivojevic 2021/01/17 04:42
The values reported on port2 are relative and normalized to port1.
As the output on port1 varies with frequency ...
On Sun, 17 Jan 2021 at 04:38, <ploegmma@gmail.com> wrote:
John Gord 2021/01/16 21:09
The NanoVNA receives with a narrow bandwidth at a limited number of frequencies.  If one of those frequencies is not identical to your input signal, you will miss it or see it at a low amplitude.  Try measuring over a much smaller range, say 6.95MHz to 7.05MHz for your 7 MHz signal.
Something like the tinySA is much more suited for looking for signals over a wide frequency span.
On Sat, Jan 16, 2021 at 07:38 PM, <ploegmma@gmail.com> wrote:
David Eckhardt 2021/01/17 17:06
Unless you set your o'scope to 50-ohms or use a 50-ohm through terminator,
the input is high impedance, usually 10 Meg.
> This is what I did:
> 15MHz
> This is what I see:
ploegmma 2021/01/17 09:57
Ah, yes, that makes sense. I will try that and see what results I get. Thnx
ploegmma 2021/01/17 10:16
That's something I also didn't think of. I feel pretty stupid by now. I will use a T-BNC with 50 ohm termination and 1X setting and see what difference that makes. Thnx.
