Measuring Choking Impedance
vk2qv 2020/06/27 01:38
Hi
Can I measure choking impedance of a choke balun using this? If so how?
Appreciate your help on this.
Cheers
randmental 2020/06/27 12:14
You can, search this forum and also the Facebook forum
-------- Original message --------From: "vk2qv via groups.io" <vk2qv=yahoo.com@groups.io> Date: 2020/06/27 11:35 (GMT+02:00) To: NanoVNAV2@groups.io Subject: [NanoVNAV2] Measuring Choking Impedance Hi Can I measure choking impedance of a choke balun using this? If so how?Appreciate your help on this.Cheers
Siegfried Jackstien 2020/06/27 10:56
i measure attenuation between port 0 and port 1 and connect the baluns
shield to the two ports hot wire (inner conductor)
you wanna measure how much choking the balun has so you have to connect
the 2 ports to the two spots between you wanna see the "attenuation" ...
means connect both shields (balun in and out) to both hot wires of the
analyzer ...
you should measure a high attenuation between the 2 ports (the choking
impedance represents a high resistance)
hope that helps
Am 27.06.2020 um 08:38 schrieb vk2qv via groups.io:
Rasika Liyanage 2020/06/28 01:28
thank you so much sigi for the quick reply. my vna v2 is on the way.
cheers, ras vk2qv
On Saturday, 27 June 2020, 08:59:05 pm AEST, Siegfried Jackstien <siegfried.jackstien@freenet.de> wrote:
analyzer ...
hope that helps
