Mac Support NanoVNA-2
Rens Dijkshoorn 2020/04/26 14:42
just found that the current Github has added support for MacPort and Homebrew for
installing the NanoVNA-QT app.
I can be installed with sudo port install NanoVNA-QT. I found that you have to define
the USB device using Other under Devicec tab to /dev/cu.usbmodemDEM1 which
is the same what is already set. De nanoVNA-2 display should then o black and display
NanoVNA V2_2 USB MODE.
Tested on OSX 10.11.6
73's | Rens PA3AXA
CT2FZI 2020/04/26 23:08
Good news!
Thanks for sharing! Let us know how it goes.
*73 de Luís, CT2FZI*
*QRV @ 145.300 MHz | **CQ0VMST (VHF REP Monsanto)*
<http://goog_717545661>
http://www.ct2fzi.net
On Sun, 26 Apr 2020 at 22:42, Rens Dijkshoorn <rens@offlinemedia.nl> wrote:
