MCULIB #Compiler
hwalker 2020/05/19 07:07
Salil Tembe wrote:
"..I forgot that Gabriel hasn't uploaded the mculib folder to git. It contains all the drivers. Is there any other link to the source which contains all the dependencies?"
Salil,
Hugen was able to compile the firmware for his prototype NanoVNA-V2 (same as Gabriel's project but with case and battery) so the complete source must be available somewhere. Gabriel is a member of this group and may be able to assist you.
Dragan Milivojevic 2020/05/19 16:22
https://github.com/gabriel-tenma-white/mculib
On Tue, 19 May 2020 at 16:07, hwalker <herbwalker2476@gmail.com> wrote:
DiSlord 2020/05/19 08:09
I can compile firmware under Windows, use eclipse
Sources:
MCULIB
libopencm3 version for gd32f3
https://github.com/nanovna/libopencm3-gd32f3
NanoVNA V2
https://github.com/nanovna/NanoVNA-V2-firmware
Under windows need install python, and fix
>libopencm3\mk\genlink-config.mk
>libopencm3\mk\genlink-rules.mk
All shell commands
>shell $(OPENCM3_DIR)
Change on
>shell python $(OPENCM3_DIR)
Also in NanoVNA-V2-firmware need set correct path MCULIB and libopencm3
>MCULIB ?= persist/mculib
>OPENCM3_DIR ?= persist/libopencm3
Before compile NanoVNA V2 need build libopencm3
pa3wle 2020/05/19 13:54
I got it compiling on Debian.
Indeed change the Makefile to point to other two repos and build those first.
I used the arm none eabi compiler from the Debian repository.
Salil Tembe 2020/05/20 06:37
Thanks for the git link to the MCULIB. I will clone the repo and try to do a first compile this weekend.
