Last FW of Git only LCD does not work normally
softhyunji 2021/12/26 23:40
I am using NanoVNA V2 Plus 4 version.
It uses a 4" LCD.
Clone the last F/W in Git and compiled it.
After downloading this, the LCD does nothing.
However, I saw that Sweep works normally by connecting via USB from the Nanovna-Server.
I would like to edit the source and add some other features.
When I restore with
nanovna-v2-20210726-v2plus4.bin everything is fine.
nanovna-v2-20201013-v2plus4.bin
When restored to , nothing is displayed on the LCD.
What's the problem?
What is the solution?
please help me
thank you.
Vladimir Lebedev 2021/12/27 06:44
Hello!
You have a new hardware version of NanoVNA-V2Plus4 with changed display connection.
Please use last stable FW version from developer team
https://nanorfe.com/downloads/20210726/nanovna-v2-20210726-v2plus4.bin
or newest expreimental version
https://nanorfe.com/downloads/20211227/nanovna-v2-20211227-v2plus4.bin
All this can You find on https://nanorfe.com website of developer. All earlier FW version not works.
Brgds
softhyunji 2021/12/27 10:25
First of all thanks for your kind reply.
I want to modify the source to add communication protocol.
Now , is the final source code other than the compiled bin file not being released anymore ?
DiSlord 2021/12/28 05:40
> released anymore ?
As i know last hardware have different lcd module, no open sources code or information about lcd avaible. But connection work, so you can conrtol V2Plus4 on CPU side.
I think possdible use this sources, if replace lcd, need search 4inch st7796 module.
Mike C. 2021/12/28 10:29
Can the display be flipped? I don't like running the VNA with the cables
facing down. (I don't have one yet but that would be a show stopper if
it can't)
Mike C.
On 12/27/2021 9:44 AM, Vladimir Lebedev wrote:
DiSlord 2021/12/28 20:44
Display-flip display option
Save settings after config-save
