Hello
So I bought the Nanovna H4. I can not use the "transform" function
If I tell him a velocity coefficient less than 1 for example 0.86, the nanovna does not take it, ideas?
Thank you
Hello
Thank you
I think the velocity factor needs to be entered in percent, so 86
instead of .86.
hmm ... maybe you have to add it in percent?? means 82 and not 0.82
Am 12.03.2021 um 15:13 schrieb Pascal CASTRATARO:
That is correct. Velocity Factor should be entered as a percent value. Example: 0.66 would be entered as 66.
