Issue with calibration and S11 parameter
shlomi.bouscher 2023/12/27 05:13
Hi all!
I've encountered a calibration problem with my NanoVNA V2 Plus4. So far I've been using the calibration set that arrived with the NanoVNA. Checking a simple SMA wire gave a S11 parameter of -20dB around 1-3 GHz which is fairly high. I've checked the same SMA cable in a more professional keysight VNA and found that its S11 values are -35 to -40dB.
This -20dB issue is bothering me since the noise floor for the S11 parameter should be ~-40 to -50 dB. Also the S11 plot looks quite deterministic without any observed noise.
This leads me to believe this is a calibration issue. I've checked the calibration both through the NanoVNA software and my Matlab code, both giving identical results.
Am I missing something? Any help would be appriciated.
Thanks in advance!
Shlomi
nanov2support 2023/12/27 10:02
Hi, the V2 is a T/R VNA, meaning port 2 can not transmit and so port 2 match error can not be calibrated out. With a cable you will measure the port 2 return loss, which will be around 16 to 20dB. To measure the cable's return loss we recommend terminating the cable with a good quality 50 ohm load. The 50 ohm load provided with the V2 Plus4 will give ~30dB return loss at these frequencies.
shlomi.bouscher 2023/12/27 23:05
Hi!
Thank you very much for the fast response.
I have checked your suggestion (cable + 50Ohm cap) and indeed the S11 parameter is less than -30dB.
I'm trying to understand what to expect for S21/S11 measurements on two-terminal transmission lines. If the port 2 match error is around -16 to -20 dB, does it mean that measuring S11 values below this error at a two-terminal measurement is impossible? What would be the best course of action if I want a decent measurement like that?
Best, and again thank you for your quick reply!
nanov2support 2023/12/28 08:01
Hi, to improve the port matching of port 2, you can add a 6dB attenuator to port 2, which will improve the return loss by up to 12dB while only lowering dynamic range by 6dB.
Bob W0EG 2023/12/28 13:59
As was previously suggested by support, cable impedance can be measured as
a one-port measurement. Terminate the far end of the cable with a quality
50 Ohm load and read S11. You can also measure the cable loss by
terminating it in a good quality short. The loss will equal 1/2 the
magnitude of S11.
On Thu, Dec 28, 2023 at 11:01 AM nanov2support <edelswartz123@gmail.com>
