Is there any battery power indicator in Nano VNA V2 Plus 4 LCD
Leif M 2022/04/29 15:53
I have a new Nano VNA V2 Plus 4. I am just now charging the battery, so I have not had time play with the Vna a lot. But there does not seem to be battery level indicator on the LCD. There are some leds blinking, but they'll be invisible, when I close the box.
Dave (G1OGY) 2022/04/30 10:30
Charge LEDS are visible on the flat bottom face of the device.
On Sat, 30 Apr 2022 at 05:51, Leif M <leif.michaelsson@gmail.com> wrote:
Leif M 2022/04/30 04:17
I have seen the light. All four of them
Siegfried Jackstien 2022/04/30 16:48
In my saa2n and in my v2plus4 i drilled 4 extra holes in the side of the case
for easy see the charge leds even if the unit lays flat on the table... Ok ok
you loose warranty..but its an easy job...
Dg9bfc sigi
Am 30.04.2022 13:17 schrieb Leif M <leif.michaelsson@gmail.com>:
> Thanks
F6GLJ 2022/10/05 13:10
Hello. I just received my Nano VNA V2 Plus, and I'm surprised: there is no battery? Or is it not connected?
It only works when plugged into a USB port. I hesitate to open it so as not to lose the guarantee.
Thank you for your reply.
Michel F6GLJ
Lou W7HV 2022/10/06 05:55
It is shipped without a battery.  It takes an 18615 without tabs and without protection circuit that fits into an internal battery holder. The claim is shipping with li-ion battery is problematic.
