How to get data about the phase about S11 and S21 parameter
ndashishyadav 2024/07/06 00:34
I want to use Nano VNA as Radar source and using Inverse Fast Fourier Transform using S11 and S21 data do the Radar imaging . I am able to retrieve the data from s11 and s21 but also want data about phase for accurate plotting . How can I get it?
W0LEV 2024/07/06 16:05
S11 and S21 are vector parameters. They can be read either as R ± jX (in
your case, amplitude) or R @ angles. You have the complex expression of
these parameters inherent in the measurements but likely not displayed.
As a starter, check the Smith Chart representation of these parameters.
You'll find both the real and complex portion of the required parameters
expressed in several formats which you choose.
Dave - WlLEV
On Sat, Jul 6, 2024 at 3:59 PM ndashishyadav via groups.io <ndashishyadav=
Jim Lux 2024/07/06 09:07
the .s2p file has real and imaginary parts of the measurement (or mag/phase).
So if you get the file out, you’ve got what you need.
The “TDR” function is basically doing an iFFT inside the unit.
. How can I get it?
