Flash firware with NanoVNA QT
Tarquin Roode 2020/09/15 10:08
Hi
I have my new Nano VNA V2 it has FW 2020 05 01 installed
How do Install new firmware using the Nano VNA QT software?
There is no menu option for FW upload?
Sorry if it appears to be a stupid question.
Tarquin Roode
ZR1TR
hwalker 2020/09/15 13:44
Tarquin,
See page 29 of the user manual at https://github.com/nanovna/NanoVNA-QT/blob/master/ug1101.pdf .
With the SAA-2 in DFU mode, when you select the correct serial port in VNA-QT the program will ask if you want to update the software. No menu option involved.
Siegfried Jackstien 2020/09/15 21:06
in the v2 you find an option to switch it in dfu mode
or switch on with left button pressed (that also switches to dfu mode)
now fire up nano vna qt ... connect to device and if in dfu mode soft
will ashk if you wanna flash firmware
click yes ... select file ... and after a few seconds the device reboots
with new firmware
easy
Am 15.09.2020 um 17:08 schrieb Tarquin Roode:
