Firmware options
Karl Jan Skontorp 2020/11/25 13:31
I hope someone can give me some information regarding firmware for my NanoVNA SAA2N
I have bought and just got a NavoVNA-SAA2N, and is a bit confused about which firmware to use. I'm a bit disappointed as this unit does not have the same console command interface as the the other NanoVNAs, the one I'm missing is the screen dump function. I think I have seen some place that the firmware for these utnits have been upgraded with a screen dump function, but I cannot find the message.
To be sure about my unit, I have the following description, "black metal box" with 2 N-connectors and 3.95" screen.
Label on the back:
SAA-2N
Simple Vector Network Analyze
Freq 50kHz-3GHz
HW version 2.2
S/N N2010xxxx
Made in China by Zeenko
Display following information on screen:
NanoVNA 2_2
Software copyright @edy555 et a1
Hardware designed by OwOComm
Licensed under GPL.
https://github.com/ttrftech/NanoVNA
https://github.com/nanovna/NanoVNA-V2-firmware
Version: git-20200617-11:29:36
Kernel: None
Compiler: gcc
Architecture: arm Core Variant: N/A
Port info: GD32F383
Platform: BARE METAL
Board: NanoVNA V2_2
Has FPU: yes
I have checked the github mentioned above, the "ttrftech" seems to be ok, the screen shows a version from 17. June 2020, but on github the there are a version from the 20. June and the one from 21. March. The version from the 17. June is not there.
I suppose the version 0.8.0 from 20200620 is ok for my unit.
Another site is also mentioned on the screen, https://github.com/nanovna/NanoVNA-V2-firmware. Here, there are newer versions, lik the one dated 20201013. I go to the link: https://nanorfe.com/nanovna-versions.html to find the correct version for my unit. But the only version 2.2 I find only have a 2.8" screen. I conclude that none of the firmware version at this site can be used on my unit! Is my conclusion right?
Are there any other options for working firmware versions to my unit?
Best regards
Karl Jan - LA3FY
Louis Wilen 2020/11/25 16:52
See:
https://forum.amsat-dl.org/index.php?thread/3467-nanovna-v2-3ghz-2-2-version-4-inch-display-saa-2n/
*So the one to use -- and I am using this one, so I know it works
correctly -- is the "blackmagic" version at this URL:*
https://nanorfe.com/downloads/20201013/nanovna-v2-20201013-v2_74.bin
Louis
W3VVV
On 11/25/2020 4:31 PM, Karl Jan Skontorp wrote:
hwalker 2020/11/28 07:07
On Wed, Nov 25, 2020 at 01:45 PM, Karl Jan Skontorp wrote:
... I have bought and just got a NavoVNA-SAA2N, and is a bit confused about which firmware to use. I'm a bit disappointed as this unit does not have the same console command interface as the the other NanoVNAs, the one I'm missing is the screen dump function. I think I have seen some place that the firmware for these utnits have been upgraded with a screen dump function, but I cannot find the message.
Karl,
Both CHO45 and DiSlord have submitted pull requests to Gabriel which add screen dump to the V2 firmware. Gabriel has accepted the pull requests so her next firmware release should include the screen dump function.
DiSlord has released a beta firmware which includes the screen dump function. It is working quite well with OneOfEleven's latest NanoVNA-App.
Siegfried Jackstien 2020/11/28 17:36
I sent karl the beta to try
Greetz sigi dg9bfc
Am 28.11.2020 16:07 schrieb hwalker <herbwalker2476@gmail.com>:
