Feature Request: is there Firmware for battery status on LCD?
Neal AB6G 2024/11/09 08:30
Does anyone know if there is firmware that places a battery status level indicator on the LCD screen?  And if this firmware is stable?
I have no idea what the V2Plus4 designers were thinking with the LED dot indicators on the back bottom of the case.  When using the VNA, you can't see them.  And there was room for these dot LEDs on the side of the case, and on the top of the case.   There is a charge controller chip inside the V2Plus4.  So there must be status information available.  And there is a LOT of room on the LCD, vertically above and below the CAL status letters on the left side of the screen.
Will NanoRFE update the firmware to include a battery status indicator?   I guess not, since the most recent firmware update is 3+ years ago.
Is there good working third party firmware that has added an on-screen battery status display icon?
Neal
O-B-1 2024/11/13 01:38
I just checked mine and charge it before I start.
Yahoo Mail: Search, Organize, Conquer
On Sat, Nov 9, 2024 at 20:00, Neal AB6G via groups.io<nealix=gmail.com@groups.io> wrote: Does anyone know if there is firmware that places a battery status level indicator on the LCD screen?  And if this firmware is stable? I have no idea what the V2Plus4 designers were thinking with the LED dot indicators on the back bottom of the case.  When using the VNA, you can't see them.  And there was room for these dot LEDs on the side of the case, and on the top of the case.   There is a charge controller chip inside the V2Plus4.  So there must be status information available.  And there is a LOT of room on the LCD, vertically above and below the CAL status letters on the left side of the screen.
Will NanoRFE update the firmware to include a battery status indicator?   I guess not, since the most recent firmware update is 3+ years ago. Is there good working third party firmware that has added an on-screen battery status display icon? Thanks, Neal
Siegfried Jackstien 2024/11/14 17:02
in my v2plus4 and in my saa2n i made 4 additional holes in the side of
the case to see those led also when the unit lays flat on the bench
battery indicator needs an additional wire to be soldered on the battery
and towards the display
the fw from disloard has that function added ... at least on the saa2n
... on the v2plus4 i am not sure (but maybe displord may aswer that detail)
i do NOT use the original fw ... not on the v2plus4 and not on the saa2n
... cause the fw from disloard is much better in my view
these 4 fw versions are the newest from him (with and without sd card
support)
hope that helps
ps you have to add that wire to the display to have the battery
indicator on screen
Am 09.11.2024 um 17:30 schrieb Neal AB6G via groups.io:
Zik 2024/11/18 11:11
Thank you  Siegfried Jackstien
One question?
*Whitch firmware is suitable for the  V2 Plus4 (no pro, device by default)? Is it the "V2Plus4_old v1.3.31" one?*
Is there any tutorial to add a SD?
v2 version it works with our V2 Plus4?
Thank you in advance
Neal AB6G 2024/11/23 09:01
@Siegfried
The firmware that you attached to your message is Dislord V1.3.31 for the V2Plus4.
I am new at learning where to look for information about Dislord FW.   When I use google,  I only find
a FaceBook group that shows Dislord V1.3.25 from June 2024.   Where do we find information and the
download location for this more recent v1.3.31 that you attach?   Is there a hidden Dislord group, or
a private email list?
And finally, if the v1.3.31 is a Beta, are there any known issues that I should be made aware of?
Thanks so much for your help and mentoring.
Neal
Siegfried Jackstien 2024/11/25 07:17
i do not know the differences between 1.3.25 and 1.3.31 (and versions in
between)
dislord sometimes makes add ons or changes and sends the new version out
in the test team
https://groups.io/g/nanovna-beta-test
so yes its a group in groups.io
its a beta yes ... but its ok to be used (i have it also on mine)
Am 23.11.2024 um 18:01 schrieb Neal AB6G via groups.io:
