Dual calibration?
Leif M 2022/04/29 22:44
Is it necessary to calibrate both NanoVNA and PC software. I would think that it is better to have calibration only in computer apps/software.
I ask In Nano VNA V1 forum arose a question, that is it necessary to calibrate the NanoVNA and the computer SW.
schweppe 2022/05/01 11:01
Yes, you must calibrate the Software again, because the SW has no access to
the calibration data stored in NANOVNA.
Von meinem Huawei-Telefon gesendet
\-------- Ursprüngliche Nachricht --------
Von: Leif M <leif.michaelsson@gmail.com>
Datum: So., 1. Mai 2022, 06:59
An: NanoVNAV2@groups.io
Betreff: [nanovnav2] Dual calibration?
Leif M 2022/05/01 10:01
I understand. But NanoVNA-App has an  option to use either calibration from device or from app. Is the option working or not, I have no idea. NanoVNA-App is currently only PC software which works with my new VNA V2 in W7/32.
Rich NE1EE 2022/05/01 10:53
nVNA-F 2.2 BH5HNU firmware 1.0.4
nVNA-H v3.6_MS firmware 1.1.01
nVNA-H4 v4.3_MS firmware 1.1
Windows 10 Pro x64
I have been in the place where I don't understand what is being posted, so my sympathies.
I have used NanoVNA-App with these.
Both options work for me.
I don't have it running now, but in NanoVNA-App, I press the button on the left with all the arrows to download the VNA sweep settings. I understand that it downloads the VNA cal in use at the time. So if I have Recalled 2, for example, then that cal is used by NanoVNA-App. Perhaps is does not read the cal data, but simply downloads the sweep, assuming that a good cal is in use, and the sweep data is good.
Or I can disregard the VNA cal, and run a cal from NanoVNA-App. I'm sure you have seen the dialog for that.
Once the NanoVNA-App cal is done, save it or not (I do, with a specific name).
Then click the Set Sweep button. It applies the cal to the current sweep.
Then choose the cal from the drop list, and run a sweep.
I have run a VNA sweep, followed by a NanoVNA-App sweep, and they compare well.
~R~
Rich NE1EE 2022/05/01 11:34
If you choose to use the VNA cal, then have the cal in use when you run the sweep from NanoVNA-App. Select VNA from the Cal drop down list.
If you choose to do a cal in NanoVNA-App, then tap CALIBRATION > RESET on the VNA to send raw data to NanoVNA-App. Use that data to do a SOLT cal. Select App from the Cal drop list. Run a sweep.
You should get a pretty close match doing both these.
