Dislord v1.3.25 vs. V2Plus4 screen buttons
nanov2support 2024/11/24 06:12
Hi, these symptoms could still be a touch calibration issue, since touch calibration corrects both offset and scaling. Can you try performing the touch calibration again and saving the calibration through CONFIG / SAVE?
On Sat, Nov 23, 2024 at 4:51 PM Neal AB6G via groups.io ( http://groups.io ) <nealix= gmail.com@groups.io > wrote:
Neal AB6G 2024/11/25 12:09
You were correct.   This odd behavior was indeed simply touch CAL needed.
I used the mechanical buttons to select the CONFIG menu and then TOUCH CAL,
since I could not use the on-screen buttons.
Everything is fine after:
1.  Perform MENU -> CONFIG -> TOUCH CAL
2.  Perform MENU -> CONFIG -> TOUCH TEST
3.  Perform MENU -> CONFIG -> SAVE CONFIG
Thanks again for your suggestion.
Neal
