Dragan Milivojevic 2021/05/09 01:36
Don't remember what the command was but there is one,
NanoVNA-Saver has support for 401 points on H4 and when
it is set, the device shows at the bottom of the screen the new setting.
Command should be the same as on H version so you could use that
to verify ...
On Sun, 9 May 2021 at 01:31, Joe Smith via groups.io <joeqsmith49=
yahoo.com@groups.io> wrote:
> I currently don't have the H4 hardware to run your firmware on. From
> your Help, it does not appear to have any sort of Point or Size command and
> I assume it can only be changed then though the GUI. Once the user sets
> the number of points, does this setting remain through a power cycle?
> Maybe stored with the other cal settings?
> I run the Nano headless and don't use the LCD, touchscreen or buttons.
> When I run a SOLT, the software stores all the settings with the
> coefficients. When I load the cal file, the software properly sets up the
> VNA. Having to manually change the number of points opens the door for the
> user to make a mistake.
> Its possible for me to reverse engineer the undocumented firmware but
> would require a fair amount of time, which is why I was looking for an
> interface spec.
