Default settings other than 50 ohms?
jf08056 2023/09/27 07:01
I am new to this and I have looked but cannot find anything to tell me what a couple of the setting do.  There are two that let you change from the default of 50 ohms.  Under the Measure menu there is "Measure R1=50 ohms".  What does this do?   Then under the Display menu there is "Port-Z 50 -> 50 ohms".  The Port-Z setting centers the Smith chart but what else does it do, if anything?  One last question (for now), Under the Calibrate menu what does "Enhanced Response" do?  Thanks.
Jim
nanov2support 2023/10/02 19:35
Hi, the enhanced response calibration allows more accurate S21 measurements and should always be enabled. Port Z calculates reflections based on a different characteristic impedance, but note this does not affect the input impedance of the ports, so is not a true way to change the characteristic impedance of the system.
