Ch0 Output Failure
Simon G8DMN 2023/04/10 01:49
What signal level should there be from the Ch0 port? I'm seeing nothing on a scope. After a Cal the VNA traces are full-screen rubbish, and there is no change irrespective of any load on the connector. I suspect one of the analogue switches is faulty, does anyone know what type they are?
Blue LEDs under ADF devices are on. Sweeping signals present on a large cap in the middle of the board.
I have tried a full reset - makes no difference. Has been working fine, bought late 2021.
Any ideas short of buying another one?
Jim Lux 2023/04/10 08:46
Around 0dBm.
I'm seeing nothing
I don't know that my old NanoVNA2 schematic (attached) is the right one,
but those rf switches are quite ESD and DC sensitive. It doesn't take
much to destroy them. Back in the archives more than a year ago,
there's suggestions for protection devices that have low parasitic C.
Simon G8DMN 2023/04/11 01:50
That's sort of what I thought (0dBm). Last successful use was tuning up a 7MHz wire dipole - could well be static.
Thanks for schematic.
I wonder how well it would work with permanent 3dB pads on the connectors? (when fixed).
Simon
Bob W0EG 2023/04/11 15:10
The Nano VNA 2 Plus 4 is a fine instrument for the price. I use it to
measure passive components, such as filters, and for education. However,
measuring antennas involves risk to the VNA as static charges can damage
the unprotected inputs and strong signals can degrade accuracy.
On Tue, Apr 11, 2023 at 8:58 AM Simon G8DMN via groups.io <simon.rundle=
talk21.com@groups.io> wrote:
Simon G8DMN 2023/04/12 01:19
We live and learn.
It turns out there's quite a lot of info about and sufferers of this problem. Perhaps there could be larger / louder warnings about this on the various web pages about this device.
Perhaps the next generation of these VNAs could include some protection - I realise it might result in poorer accuracy.
Simon
Jim Lux 2023/04/12 08:11
On 4/12/23 1:19 AM, Simon G8DMN via groups.io wrote:
> We live and learn.
I don't know that it would result in poorer accuracy - most of the
protection devices effectively put a small (few pF) shunt C on the port,
and that would probably come out in the calibration.
nanov2support 2023/04/12 10:10
Hi, all ESD protection devices we tested degraded the linearity of S11 measurements to an unacceptable level, so they are not used. In the VNA6000 series we switched to components with a higher ESD rating instead. The frontend ICs are now rated for 4000V HBM instead of 1000V to reduce the occurrence of damage. However, we recommend following ESD precautions when performing measurements. Thanks
Leif M 2023/04/13 11:40
This is interesting  and good to keep in mind.
I wonder if there are SMA adaters( or others) with low capacitance ESD diodes built in. They could be usefull elsewhere if not here.
Bob W0EG 2023/04/14 08:23
If you can afford one, consider using a dedicated antenna analyzer,
essentially a one port VNA but rugged. The RigExpert units are very good
( made in Ukraine).
On Fri, Apr 14, 2023 at 12:32 AM Leif M <leif.michaelsson@gmail.com> wrote:
W0LEV 2023/04/14 15:38
I've previously posted this, but here it is again:
MiniCircuits VLM-33W-2W-S+ SMA Limiter
You can look up the complete specifications on the MiniCircuits site.
Jim Lux 2023/04/14 10:14
> Dave - WØLEV
Of course, at $63 each, buying a pair of these costs more than the
instrument its protecting <grin>
