NanoVNA V2 / Forum
To post, join https://groups.io/g/NanoVNAV2
Can this 7" touch screen be used with nanoVNA_V2 ?
Alberto I2PHD 2020/07/16 16:03
I have the 7" touch screen shown in the two photos below as a result of an aborted project, which did not ever see the
light.
I am wondering if I can use it with the S-A-A-2 nanoVNA....
/*73 Alberto I2PHD*
<<< http://www.weaksignals.com >>>/
Siegfried Jackstien 2020/07/16 14:58
its a serial device and also has a touch display ... so ... i would say
"maybe"
cause there is no firmware that supports it (yet)
Am 16.07.2020 um 14:03 schrieb Alberto I2PHD:
Alberto I2PHD 2020/07/16 17:06
> "maybe"
> dg9bfc sigi
The firmware aspect maybe could be taken care of... but what about the hardware ? How could it be connected to the S-A-A-2 ?
/*73 Alberto I2PHD*
DiSlord 2020/07/16 10:14
> "maybe"
> dg9bfc sigi
> > of an aborted project, which did not ever see the light.
I already answer about it see:
https://groups.io/g/NanoVNAV2/message/678
As can see this LCD on SSD1963 driver
See datasheet
https://www.chipcad.hu/Image/GetDocument/en/3163/ssd1963%20controller.pdf
Page 16
No SPI data format supported, only parallel data interphace. No pins on CPU for this
Alberto I2PHD 2020/07/16 23:07
> See datasheet
> Page 16
Thanks DiSlord for your answer. Yes, I can see now that, apart from the firmware, the major show stopper is the fact
that this panel can be interfaced only with parallel data...
Well, let's hope that someday a S-A-A-2 nanoVNA with at least a 4"display will materialize....   2.8 inches are too few....
/*73 Alberto I2PHD*
Siegfried Jackstien 2020/07/16 21:12
Hello ALberto
4 inch is already solved ...
buy a v2 ... buy a 4 inch screen
add the firware for that bigger screen
done
ps ... a 5 to 8 inch would be fun for a bench unit and still usable
stand alone (away from bench)
Am 16.07.2020 um 21:07 schrieb Alberto I2PHD:
