I am having difficulties with the NanoVNA and my Butternut HF6V antenna SWR readings.
What difficulties?
Dg9bfc sigi
Am 19.08.2023 05:57 schrieb Tim <t.m.kelly@outlook.com>:
readings.
High SWRs on 10 meters. 28-29.5 = 2+ SWRs. All other bands = infinite. Yes I calculated each band on the NanoVNA individually. I only have the SWR trace showing, SWR checked, with a .25 scale on the right side.
The antenna has never failed me. But I am going to check it today.
Than you for your reply.
Tim Kelly
-------- Original message --------
From: Siegfried Jackstien <siegfried.jackstien@freenet.de>
Date: 8/19/23 10:29 AM (GMT-05:00)
To: NanoVNAV2@groups.io
Subject: Re: [nanovnav2] Any Butternut Anntena Users
What difficulties?
Dg9bfc sigi
2:1 SWR is not a bad match...... Most modern radios can correct for this.
> Tim Kelly
> What difficulties?
> Dg9bfc sigi
> SWR readings.
Calibrate for the frequency range of interest. Then you get more
measurement points
AFAIK.
Raj
On 19/08/2023 9:27 AM, Tim wrote:
Hi
Looks like a broken solder joint right at the end of ten meter vertical part,(disconnecting the whole remaining length of the vertical.....)
4x1rv
I connected my old MFJ to my Butternut coax and was able see readings. Hooked up the NanaVNA and discovered a bad connector at the NanaVNA and coax connection. I replaced the connector and I am now receiving readings on the NanoVNA.
But the readings are different from my setup about a year ago. Here are my SWR reading from low point on the frequency to high point.
10 m. 1.5. 2.5
15m. 1.7. 2.7
20m. 1.7. 2.25
30m. 3.0.+ 3.0+
40m. 1.25. 3.0+
80m. 1.25. 3.0+
They all seem high on the upper side of the bands. 30m has me confused.
Thank you for any suggestions especially on 30 meters.
Tim Kelly
Date: 8/19/23 11:58 PM (GMT-05:00)
On Sat, Aug 19, 2023 at 6:49 PM Tim <t.m.kelly@outlook.com<mailto:t.m.kelly@outlook.com>> wrote:
Tim Kelly
From: Siegfried Jackstien <siegfried.jackstien@freenet.de<mailto:siegfried.jackstien@freenet.de>>
To: NanoVNAV2@groups.io<mailto:NanoVNAV2@groups.io>
What difficulties?
Dg9bfc sigi
Am 19.08.2023 05:57 schrieb Tim <t.m.kelly@outlook.com<mailto:t.m.kelly@outlook.com>>:
Thank you. I will look into that situation.
Tim Kelly
Date: 8/20/23 2:08 PM (GMT-05:00)
10 m. 1.5. 2.5
15m. 1.7. 2.7
20m. 1.7. 2.25
30m. 3.0.+ 3.0+
40m. 1.25. 3.0+
80m. 1.25. 3.0+
Tim Kelly
Tim Kelly
What difficulties?
Dg9bfc sigi
Without looking it up online, was the Butternut designed to operate on
30-meters? I seem to remember only the traditional five bands were
addressed.
> on the NanoVNA.
> 10 m. 1.5. 2.5
> 15m. 1.7. 2.7
> 20m. 1.7. 2.25
> 30m. 3.0.+ 3.0+
> 40m. 1.25. 3.0+
> 80m. 1.25. 3.0+
> Tim Kelly
> From: W0LEV <davearea51a@gmail.com>
> Dave - WØLEV
>> Tim Kelly
>> What difficulties?
>> Dg9bfc sigi
>> SWR readings.
> *Dave - WØLEV *
Exactly what type of ground system do you have on that antenna?
What type of coax and is the coax buried or above ground? Is the coax
properly waterproofed at the connection?
73 Tom
> 10 m. 1.5. 2.5
> 15m. 1.7. 2.7
> 20m. 1.7. 2.25
> 30m. 3.0.+ 3.0+
> 40m. 1.25. 3.0+
> 80m. 1.25. 3.0+
> Tim Kelly
> Dave - WØLEV
> on the right side.
> Tim Kelly
> What difficulties?
> Dg9bfc sigi
> *Dave - WØLEV
www.avg.com
1st off something has changed - my name / instead of call sign on top KD0CAC
Next is if you have made any changes or moved the antenna , Butternut only has a couple weak points - one of the capacitors does not have correct support & wind can break the capacitor [ do not remember which on ] , next is other connections - less of an issue , but anything sitting outside over time will fail .
Try using the Smith Chart on the Nano VNA - what your looking for is what type of reactance [ capacitive or inductive ] is causing the higher SWR - that would point where to look .
Also you can just take the antenna down & apart , then after cleaning & applying copper anti-sieze on all connections , just reassemble as new out of the box - you should find issue during this process , you could also use a multi-meter - before disassembly / but laying something like a couple saw horses - checking each connection for resistance issue .
If and when you take the antenna down and apart, check all the capacitors
for correct value and any mechanical damage. They are the #1 failure
component in the assembly. I had a friend, now deceased, who had a
Butternut up for decades. In it's lifetime, he went through two failed
capacitors. John is correct in that they are not mechanically well
supported.
> KD0CAC
> time will fail .
