ADF4350 vs ADF4351
Wiktor.starzak 2023/08/01 02:41
Hey,
I have noticed that in my V2 Plus4 Pro i do have ADF4350 installed. Checking Analog site the slightly newer version has been improved (a bit).
Main improvements compared to the ADF4350:
* Improved 1/f in-band phase noise (5 dB)
* EVM improvement of up to 30%
* Lower PFD spurs
* Wider output range: 35 - 4400 MHz
* Small frequency/phase jumps possible without band select.
I do understand that the change probably would be unnoticeable, but do you think that maybe it is worth upgrading to fight for every 0.1dB of accuracy?
Analog: https://ez.analog.com/rf/f/q-a/76030/adf4351-vs-adf4350---what-are-the-differences
István 2023/08/10 01:06
My question is, has anyone made such an improvement on their device?
On a parallel forum, - where there was a history of this topic ( three-year old theme was) , no response was received.
I have the feeling that by changing and improving the reference oscillator, we can have a greater influence on the phase noise and, of course, on the frequency stability.
Istvaan
nanov2support 2023/08/10 08:35
Hi, what we know is only changing ADF4350 to ADF4351 does not make any
measurable difference in the V2 series. In VNA6000 we are using a
higher performing synthesizer circuit to achieve its lower phase
noise.
On Thu, Aug 10, 2023 at 8:29 AM István <erretrete@freemail.hu> wrote:
Siegfried Jackstien 2023/08/10 13:59
at first look for the clock that is driving the 4350/51 ... if you
change that for a low phase noise but high stability clock .. then you
are on the right track
eplacing that chip can be done later
i bet the main clock is what sets stability (and often also the phase noise)
Am 10.08.2023 um 10:06 schrieb István:
Jim Lux 2023/08/15 21:01
> dg9bfc sigi
>> (three-year old theme was), no response was received.
>> Istvaan
> _._,_._,_
I don't know that stability is a big driver - unless you're making very
narrow band measurements and a few Hz makes a difference. 1 ppm is 1 kHz
at 1 GHz, after all.
Phase noise is a bit trickier - The receive LO has a different
synthesizer than the Stimulus LO, so the noise doesn't cancel out.
But then, usually, you worry about phase noise when looking to separate
multiple signals (e.g. reciprocal mixing) - here, there's only one
signal, and what you'd care about is the noise at 5kHz out, which sets
the noise floor. I suspect other components are bigger contributors to
the noise floor.
Taking the first hit on Mouser for a 26 MHz TCXO I see phase noise at
1kHz is -134 and -146 at 10 kHz. Bumping that up to, say 520 MHz,
you'll see an increase of 20log(20) or 26 dB. So at 5 kHz, we're
looking at probably around -116 dBc.
Since the stimulus is ~0 dBm, and the dynamic range of the system is
~80dB, and allowing for ~1kHz bandwidth in the filter (30dB), the noise
power is -86 dBm. So pretty small.
