450-OHM WINDOW LINE........OR IS IT?
David Eckhardt 2021/02/25 22:58
I was doing some modeling using SimSmith and measured values of the shack
end of my 450-foot long doublet fed with (mostly) 450-ohm window line.
I was not getting what I would expect, so I measured the Zc of a 7.17-foot
length of (claimed) 450-ohm window line. Measured values of total L and C
follow:
8.2 MHz 34.8 pF 3.51 µH Calc Zc: 318 ohms 4.85 pF / Ft
2.6 MHz 32.4 pF 3.07 µH Calc Zc: 308 ohms 4.5 pF / Ft
Measured wire center-to-center spacing is 0.85-inches
Wire is stranded AWG #16 stranded copper weld
Using an εr of 0.91, the physical parameters indicate Zc more like 430 to
440 ohms
using the calculator at: https://hamwaves.com/zc.circular/en/
So, what I have isn't 450 ohms as claimed.
REQUEST: If others have a length of this standard window line, could you
please make measurements and confirm or deny my measurement that indicate a
Zc more like 310 ohms instead of the claimed 450-ohms?
Jim Lux 2021/02/25 15:24
> shack end of my 450-foot long doublet fed with (mostly) 450-ohm window
> line.
> 7.17-foot length of (claimed) 450-ohm window line.  Measured values of
> total L and C follow:
> to 440 ohms
> <https://hamwaves.com/zc.circular/en/>
It is quite a feat to get a relative epsilon less than 1 <grin> You can
do it with ionized plasmas, but I suspect that's not what you have.
I'd guess window line, which is 90% "open space" would have an er of
around 1.2 or 1.3
Does that make your numbers come out closer?
I'm a little suspicious of that calculator - AWG 16 needs to be an inch
apart for 450 ohms with er=1
Using this one:
https://www.mantaro.com/resources/impedance-calculator.htm
51 mil diameter (AWG 16), 850 mil spacing, er=1.1 -> 400 ohms
.22 pF/inch -> 2.64 pF/ft
David Eckhardt 2021/02/26 00:13
Yes, much better calculator. Yes, I biffed it a bit on εr. Wireman gives
Vp = 0.91. I measure 0.87 which yields an εr of 1.07.
But given my measurements of L and C for 7.17 feet, I still see more like
Zc = 310 ohms, not 450.
> > line.
> > to 440 ohms
> around 1.2 or 1.3
> Using this one:
> > you please make measurements and confirm or deny my measurement that
> > indicate a Zc more like 310 ohms instead of the claimed 450-ohms?
> > *Dave - WØLEV*
> > /*Just Let Darwin Work*/
David Eckhardt 2021/02/26 00:17
Yes, it is, Jim. We're not dealing with metamaterials!! Too many things
going on in my 74 YO gray matter. With a measured Vp of 0.87, the
effective εr should be 1.07.
Dave - WLEV
> > line.
> > to 440 ohms
> around 1.2 or 1.3
> Using this one:
> > *Dave - WØLEV*
Glenn Elmore 2021/02/26 06:22
High Impedance lines become difficult, actually impossible, to measure with a conventional VNA. This is because at high impedance the TM mode becomes significant and finally dominant compared to the TEM mode so that the assumption that all e-fields are orthogonal to the direction of energy flow is no longer sufficiently accurate.  A balanced line in a low relative permittivity medium such as air and having large spacing/diameter ratio approaches two independent surface wave transmission lines.  Please see the most recent RSGB Radcom+ or a draft of the same article ( http://www.sonic.net/~n6gn/ ) as the top entry on my website for further details.
Glenn n6gn
