3D printed SMA torque wrench
Reinier Gerritsen 2020/04/25 10:03
Cheap torque wrenches on Aliexpress. Search for "Mxita sma torque wrench". Around  €15-20.
You can have it adjusted to the torque you need. Steel sma connectors need 1 Nm, gold plated brass 0.5 Nm.
CT2FZI 2020/04/25 22:24
Hi there,
I might buy one just to compare with my 3D printed wrenches.
Do you ask the seller to adjust the torque, or how do you measure 0.5 Nm ?
*73 de Luís, CT2FZI*
*QRV @ 145.300 MHz | **CQ0VMST (VHF REP Monsanto)*
<http://goog_717545661>
http://www.ct2fzi.net
On Sat, 25 Apr 2020 at 18:03, Reinier Gerritsen <r.gerritsen@idcircuits.com>
Reinier Gerritsen 2020/04/26 19:22
When you order, you can ask the seller to adjust it. I order 5 pcs, also
for my job. However, the screw setting the required torque was not
locked, so the calibration did not hold. I recently ordered a cheap
Newton meter (5N range). With a piece of wire at 125 mm from the sma
axis, you need a force of 4N to get a 0.5 Nm torque. Easily calibrated
yourself.
Op 25-4-2020 om 23:24 schreef CT2FZI:
CT2FZI 2020/04/26 12:14
You gave an idea: If you are talking about those cheap spring type Newton meter that we can find at aliexpress, I can print a 125mm SMA wrench and with a simple jig I can apply the calculated 4N, with no need of a specialized torque wrench ...
Just hang the newton meter above and apply the force till 4N.
Bob Benedict, KD8CGH 2020/05/02 07:33
I ordered a "Mxita sma torque wrench" from AliExpress in January and after 10 weeks it had not come, so I gave up on it. Eventually I was able to get a refund. The Tindie V2 page now advises that shipping is taking 60-100 days.
Bob
